Well I wanted to replicate my Uncles,so What cab and Mudguards would i use or would I have to cast both the bonnet and the Cab/Floorpan
Heres a Picture of the one I want to make
13 answers to this question
Cab and floorpan are easy - use the ones from a New Holland TM or 8560 and paint them red! Could also use the rounded cab roof from an Ertl 8670, PDC casts these. You'd probably get away with an MXU bonnet I'd say? UH Deutz TTV wheels would set it off nicely then
a mxm,is basically a tm,as fnhir said the best would be,a repliagri nh 8560,the mxm roofs are different to the tm's ,so a  roof from pdc and yes look at a britains  maxxum 125 bonnet,wheels are always difficult,look in google,and get some images of the maxxum 155 and go from there,heres a picture of a uk spec one,hope it helps john
Thanks for the help,yes I think I will use the Replicagri M160 Chassies and floorpan/cab,pdc roof and a lengthened mxu bonnet??
wheels have a more uh mcmormrick mtx175 look to them?? may be worth using the whole chassis looking at it?? maybe the cab and arches from it will work to
Or actually I might do this,the cab would be right wouldnt it??
It would be close, but the Replicagri would be pretty much spot-on except for the roof, given that the MXMs were basically blue NHs, even with the exhaust coming from the bonnet rather than from the lower engine as on the MTX
Yea but isnt`the mcCormicks bonnet right for a mxm aswell
I might do a mix of the mccormick bonnet witha m160,i need wheels off a mccormick aswell so may work out for the best
The McCormick bonnet would pass for an MXM alright I'd say, the back mudguards are all wrong though, whereas the M160's are perfect, also note differences in exhausts
Case-IH-MXM-155-1056326.jpg?height=600&width=800&quality=80
Yes i see what ypu mean,thanks for the help Denis,It`ll be a MTX Bonnet on a M160 chassies
No bother, an MXM was something I often meant to try, will be good to see as they're rare enough in model form!
Yes it will be going on a mower as the real one was on a mower up untill this year and she may be going back on it for second cut
