Guest Posted August 2, 2014 Share Posted August 2, 2014 Hi I start the JM farms ltd model farm set up in 1985 but i m not sure how long it should take to build one as i see other on here have done wonderful set ups yet mine is growing slower then the Uk economy ha ha! , advice is welcome from the more expert builders on here please , The pics are of the sheds i made in the summer of "85 " in between farm jobs i just simlpy used some 4 mm ply & balsa wood for the gutters / down pipes ( just wish id patented then ) will add pics asap Link to comment Share on other sites More sharing options...
Paul Palmer Posted August 2, 2014 Share Posted August 2, 2014 another layout,come on jon,get those pictures up,i use for buildings some britains buildings and tart up the brushwood ones,as i think in all honesty the brushwood ones are aimed at kids Link to comment Share on other sites More sharing options...
Oakley Farms Posted August 2, 2014 Share Posted August 2, 2014 We have more and more layouts popping up every day, this is great news! I agree with Paul, brushwood manufacture at great "starter shed" if your not too handy at cutting straight etc but they need tarting up whether it be cutting in skylights, adding cladding, joining two or three together. But i believe to truly get exactly what you want is to build it yourself from scratch. I can see a little layout club forming here and I'm pleased to have been involved and helped Link to comment Share on other sites More sharing options...
Jdeere6910 Posted August 2, 2014 Share Posted August 2, 2014 Have a go at one Jon, an on going project. If you have the space why not? Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2014 Share Posted August 2, 2014 Hi Come on boys there was full time farm work to be done at that time , playing out at the pub , getting married then divorced ha ha! then paying ever other tom , **** & harry off !! thats what happen well thats my story - Heres the two sheds made from 4mm ply & Balsa woods for the gutters / drains then all painted in good old gloss paint small pin nails & glue ha ha! Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2014 Share Posted August 2, 2014 Heres the 3 bay Dutch barn most farm in my time had some thing like it Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2014 Share Posted August 2, 2014 And heres the farm signs agin made in " 85 " these was made from lettering which i got from a shop in York which you had to transfer a letter at a time , then theres a pic of the spud boxs & the wooden pallet which i d made from match es again the paint will be what ever was in the house at the time at this time i was still living at home sweet home with me mum & dad The farm names are of real farms in my area theres 3 in total but i cant find the 3rd sign as yet Link to comment Share on other sites More sharing options...
Stabliofarmer Posted August 2, 2014 Share Posted August 2, 2014 Seriously, some corrugated card on the sides of those, some plastruct gutters and a new coat of paint and you've got the basis of a corker of a farm there Jon, and possibly one with the oldest buildings on the forum ? One thing I would say is, and I know it doesn't apply to all farms, a good sturdy well built baseboard goes a long way, particularly if the layout is moved around a lot and that's not just to shows but if it needs to be moved round the house and hidden from your Misses Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2014 Share Posted August 2, 2014 Hi i know what youre saying mate the Mrs & that dammed hoover ha ha! the 2 sheds are " bottom less " which is a little bit rude but the barn has a floor ." As with many that worked on "real farm " s i done a lot of floor laying & digging footings by hand , even build a shed on the last farm i worked on , I know thats the main reason my back gave way - im just not build like a builder more like a model ha ha! but with all the £££££ missing yep i ve seen some of the good works done by Alex & Paul & the other boys on here so i may follow ! Link to comment Share on other sites More sharing options...
Paul Palmer Posted August 2, 2014 Share Posted August 2, 2014 like James say Jon,a bit of a make over to the buildings and your away,the more layouts the better Link to comment Share on other sites More sharing options...
SPN Posted August 2, 2014 Share Posted August 2, 2014 Good to see a new layout coming on. The more the merrier. I use 6mm MDF boards, 610mm x 1220mm as base boards. They can warp over time, so I have glued 2x1 batens under them to keep them straight. When not in use they can be stood up against the wall. The sheds can be set out in different combinations, or for different eras. By using the same size boards you can add and subtract stuff as and when necessary. Here's a shot of two boards I use for grassland scenes. One has a grass mat glued to it. The other has part grass and part tarmac In this one you can see the join between two boards when the yard buildings are set down. Link to comment Share on other sites More sharing options...
Oakley Farms Posted August 2, 2014 Share Posted August 2, 2014 I used MDF boards for the base but taped over the joints and painted, not ideal for moving about regularly though Link to comment Share on other sites More sharing options...
0025 Posted August 6, 2014 Share Posted August 6, 2014 i use plywood/mdf laminate flooring as you can pick it up cheep or for nothing when the house floor needs doing Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2014 Share Posted August 6, 2014 Thanks for the feed back boys im looking at doing up the sheds in time ha ha! but i ve found it a lot easyer to buy the kit for her eg Tractors that far easyer me thinks Link to comment Share on other sites More sharing options...
Fenside MF Posted August 10, 2014 Share Posted August 10, 2014 blimey you have got the oldest buildings on the forum,older than me! But they are really smart a good base to start from I'd say Link to comment Share on other sites More sharing options...
Guest Posted August 11, 2014 Share Posted August 11, 2014 Hi thanks J but dont make us feel any older ha ha! young Jamie you young ones of day dont know how lucky you all are there was no HLT or anything like that in them good old days thats for sure !!!! , there was an odd model maker but they only had the early Britains models to work on , im still not sure if i started them the year before but hey what the heck i used to buy odd models from G&M when they 1st came in to the model selling world game near Leeds Link to comment Share on other sites More sharing options...
tractorboy Posted September 20, 2014 Share Posted September 20, 2014 Hi heres a few of the models i ve been buying up following good advice from Mr Alex , now im sure he said go Red ha ha! , A new MF 7624 on a s/h but nearly new 6 fr plough , then a little yellow a Cat MT 765C turn up with a s/h Britains Vaderstad - A 600 s drill & a new 7fr plough , Link to comment Share on other sites More sharing options...
tractorboy Posted September 20, 2014 Share Posted September 20, 2014 and a few more, a sprayer , a spud harvester & a JCB x Link to comment Share on other sites More sharing options...
tractorboyjules1977 Posted September 21, 2014 Share Posted September 21, 2014 good to see a nice new selection of kit turning over , anything else due to arrive ? Link to comment Share on other sites More sharing options...
Paul Palmer Posted September 21, 2014 Share Posted September 21, 2014 nice updates Jon Link to comment Share on other sites More sharing options...
tractorboy Posted September 21, 2014 Share Posted September 21, 2014 A Big Claas TT 780 in the shed , have been thinking about having 2 ha ha! but i d need to sell some of the older models & thats not easy moving them on as in real life , Link to comment Share on other sites More sharing options...
tractorboy Posted September 21, 2014 Share Posted September 21, 2014 Pick up a few items from Mr BLR models , also been stocking up on spud boxs / pallets from Globe , ,Had some spud bags & spuds from HLT Tractors to come in i think will be another MF7624 & the new MF thats out soon , , also i ve seen a big CAT id like as well ( Mainly as i ve been in one ) ON kit front , well i need some more spud kit & may be a topdown like bit of kit thenits just getting round to making some where for it to farm But i got to sell a good bit of old kit next to pay for me new plans loln as the Mrs wont give me any pocket Money !! oh & some of them nice fancy trailers Mr Alex s has , Link to comment Share on other sites More sharing options...
Paul Palmer Posted September 21, 2014 Share Posted September 21, 2014 some nice gear you have Jon Link to comment Share on other sites More sharing options...
Oakley Farms Posted September 21, 2014 Share Posted September 21, 2014 Keep it going Jon, your collection is growing Link to comment Share on other sites More sharing options...
