0025 Posted December 29, 2015 Share Posted December 29, 2015 thought I would do this as I have an old play worn claas arion 640 and a loader which I have removed from my smaller 430, hear goes! my plan is to stick the loader on with pva as it is a nice flush fit with The larger 640 Link to comment Share on other sites More sharing options...
Stabliofarmer Posted December 29, 2015 Share Posted December 29, 2015 I'd suggest going with something a more suitable than PVA as it wont bond that well to the metal. Link to comment Share on other sites More sharing options...
Paul Palmer Posted December 29, 2015 Share Posted December 29, 2015 and me James,pva is for wood really,that will not bond metal Link to comment Share on other sites More sharing options...
0025 Posted December 29, 2015 Author Share Posted December 29, 2015 ah but I want to take the loader of in the future. Maybe small amount of super glue... Link to comment Share on other sites More sharing options...
0025 Posted December 29, 2015 Author Share Posted December 29, 2015 next step, i removed linkage arms of the tractor, any ideas on what i could cover the pto up with, or should i leave it like how it is? Link to comment Share on other sites More sharing options...
0025 Posted December 29, 2015 Author Share Posted December 29, 2015 glued loader on, taken off both front wheels and put one back on, next job is gluing down the hydraulic pipes and fixing the other wheel... Link to comment Share on other sites More sharing options...
mb86 Posted December 30, 2015 Share Posted December 30, 2015 Loader is a nice match for the tractor jack. What's the Sellotape doing? Could you not get in to drill some holes and screw the loader on while you had the wheels off? Link to comment Share on other sites More sharing options...
0025 Posted December 31, 2015 Author Share Posted December 31, 2015 ah but it was easier how I did it anyway I've just about got it finished, on the front I used an old tyre like I have seen, the Sellotape was there to keep hold of mud guard so it won't fall off. Link to comment Share on other sites More sharing options...
0025 Posted December 31, 2015 Author Share Posted December 31, 2015 hear you go the just about finnished item! Link to comment Share on other sites More sharing options...
Jordan_coe2012 Posted January 1, 2016 Share Posted January 1, 2016 Like that jack nice use of the tyre to where the pto was. Link to comment Share on other sites More sharing options...
0025 Posted January 3, 2016 Author Share Posted January 3, 2016 well I took of the linkage and chopped the PTO of, then stuck on the tyre, like in real life, I like to think I've spruced up the model a bit. thanks for the kind comment Jordan! Link to comment Share on other sites More sharing options...
CX820Joe Posted December 2, 2017 Share Posted December 2, 2017 Hi Jack - bumping this topic; sent you a PM but not sure if you've seen it. Just wondered if the Loader was difficult to remove, and whether taking it off means you couldn't re attach it at some point? I presume pipes would need cutting off Link to comment Share on other sites More sharing options...
0025 Posted December 2, 2017 Author Share Posted December 2, 2017 Yea it just unscrewed, the hydraulics needed cutting, at the bottom. Link to comment Share on other sites More sharing options...
b_emmons Posted December 2, 2017 Share Posted December 2, 2017 if pipes need cutting I will leave my loaders fitted Link to comment Share on other sites More sharing options...
