scissor lift trailer
  • Replies 78
the orderd small ariels turn up today hopefully, so time allowing they will be fitted this pm hopefully
I have asked my Engineer friend who does work for me on my spud peeling machine... he reckons you can buy "proper rams" from a specialist company... he's going to get a catalogue for us... they should work off air of light oil... ummmm... now a REAL tipping one Sean... that sounds a bit sexy  ;D
sexy indeed mark, but for now heres the updated version mate
uses a 4 stage ram to lift the main body up didn't take to long to do either, just need to oil it a bit as they are a bit stiff for the lift, have alos made a 4 stage small one for the body lift but forgot the plasti strut for the mounts on it :'( :'(
go for it marky, i should be finishing of the body on this tommorrow all being well, and fixing everything into final place, prior to painting, just need to re-aline the lift arms slightly as they are ever so to much wide for the chassis 100ths of a mm but it wont sit right down flush at present, ,only other change will be the wheels ,got a couple of pairs of uh cargo trailer ones coming at toytrac
there's some tims wheels that are slightly smaller than that sean , but still have the same tread pattern , i was thinking of using them as rears on the combines
going to try a set of uh cargos i have on order for her, picking them up at toytrac hopefully
looking good sean, did you find arials just right or cut a pair up to suit
they are 50p each magnetic screw one mate but chopped down to the correct stroke on each one and refitted, took about 10 mins for each one ,very easy to do actually , next ones i do i will try and remember to take some pics to explain it for you all,
