Ferret90 Posted October 31, 2018 Author Share Posted October 31, 2018 7 minutes ago, CX820Joe said: I should make an attempt to do it myself I suppose...no confidence that's the trouble. I still remember trying to glaze the cab of the earliest Siku Lexion combine and made an utter pigs ear of it. Can't harm to have a go Go for it, I've been procrastinating Link to comment Share on other sites More sharing options...
844john Posted October 31, 2018 Share Posted October 31, 2018 53 minutes ago, Ferret90 said: Thanks John,What glue do you reckon would be best? I've done it before and it has misted I have a tube of what i believe is called cockpit glue, it is similar to pva as it dries clear and doesn't mist at all, and i find with patience it works very well. I'll take a photo of it when I'm back later Link to comment Share on other sites More sharing options...
Ferret90 Posted October 31, 2018 Author Share Posted October 31, 2018 4 hours ago, 844john said: I have a tube of what i believe is called cockpit glue, it is similar to pva as it dries clear and doesn't mist at all, and i find with patience it works very well. I'll take a photo of it when I'm back later Cheers John Link to comment Share on other sites More sharing options...
alf aphid Posted October 31, 2018 Share Posted October 31, 2018 11 hours ago, Ferret90 said: Thanks John,What glue do you reckon would be best? I've done it before and it has misted Yes I too have used an acetate type substance. You can buy various gauges if I recall correctly, have a hunt on eBay. Like a John already stated, flexibility is important in most applications. Regarding fixing, yes you are right, get glue Anywhere near and you’re in trouble. I used the tinyest touch of superglue and it worked fine, I use the gel type one. Just be so so careful maybe someone else has some other suggestions though ? Link to comment Share on other sites More sharing options...
844john Posted October 31, 2018 Share Posted October 31, 2018 This is the stuff I use, Formula 560 Canopy glue, takes a little while to set but dries clear and no fogging (good job I checked before i posted, bloody phone changed that to dogging!) Link to comment Share on other sites More sharing options...
Tractorman810 Posted October 31, 2018 Share Posted October 31, 2018 26 minutes ago, 844john said: This is the stuff I use, Formula 560 Canopy glue, takes a little while to set but dries clear and no fogging (good job I checked before i posted, bloody phone changed that to dogging!) yeah we belive you john , why would you be searching for that Link to comment Share on other sites More sharing options...
844john Posted October 31, 2018 Share Posted October 31, 2018 1 minute ago, Tractorman810 said: yeah we belive you john , why would you be searching for that I'm at a loss for words there Sean.... Link to comment Share on other sites More sharing options...
Ferret90 Posted October 31, 2018 Author Share Posted October 31, 2018 3 hours ago, alf aphid said: Yes I too have used an acetate type substance. You can buy various gauges if I recall correctly, have a hunt on eBay. Like a John already stated, flexibility is important in most applications. Regarding fixing, yes you are right, get glue Anywhere near and you’re in trouble. I used the tinyest touch of superglue and it worked fine, I use the gel type one. Just be so so careful maybe someone else has some other suggestions though ? Thanks Alastair,I've just thought the local model shop does that stuff for model trains I'll have a look Link to comment Share on other sites More sharing options...
Ferret90 Posted October 31, 2018 Author Share Posted October 31, 2018 3 hours ago, 844john said: This is the stuff I use, Formula 560 Canopy glue, takes a little while to set but dries clear and no fogging (good job I checked before i posted, bloody phone changed that to dogging!) Thanks for reply Now we wouldn't want that now John Link to comment Share on other sites More sharing options...
Ferret90 Posted October 31, 2018 Author Share Posted October 31, 2018 I've just realised the title is jd 6930s but I mean 6920s Link to comment Share on other sites More sharing options...
alf aphid Posted November 1, 2018 Share Posted November 1, 2018 Ah will try some of that cockpit glue!! Would be good to avoid the dogging !! Link to comment Share on other sites More sharing options...
Tractorman810 Posted November 1, 2018 Share Posted November 1, 2018 I use that cockpit glue, works very well, i tend to glaze with clear sheets i buy from the local model shop, all a4 in size and varying thickness avaiable, pretty cheap at arround 75p a sheet on average, move curvey the thinner i use to allow it to bend easy, its in a EMA display bit not sure its actually their product if that makes sence Link to comment Share on other sites More sharing options...
844john Posted November 1, 2018 Share Posted November 1, 2018 9 hours ago, alf aphid said: Ah will try some of that cockpit glue!! Would be good to avoid the dogging !! The thing that puzzled me the most is why the phone thought dogging was more likely what I meant than fogging, makes you wonder what the chap who wrote the software gets up to in his spare time! Link to comment Share on other sites More sharing options...
alf aphid Posted November 1, 2018 Share Posted November 1, 2018 3 hours ago, 844john said: The thing that puzzled me the most is why the phone thought dogging was more likely what I meant than fogging, makes you wonder what the chap who wrote the software gets up to in his spare time! Ha ha, the truth is there are sure to be more people looking into dogging then there are anoraks worried about the effects of fogging on their scratch builds Link to comment Share on other sites More sharing options...
Ferret90 Posted December 8, 2018 Author Share Posted December 8, 2018 It's been a while but I've decided to bite the bullet and cut the chin off the 6920 Link to comment Share on other sites More sharing options...
844john Posted December 8, 2018 Share Posted December 8, 2018 Looks so much better Ted, it totally transforms the look of the model Link to comment Share on other sites More sharing options...
Ferret90 Posted December 8, 2018 Author Share Posted December 8, 2018 56 minutes ago, 844john said: Looks so much better Ted, it totally transforms the look of the model Thanks John , yep looks better alright. I've now managed to get the weights on there... Link to comment Share on other sites More sharing options...
Fenside MF Posted December 9, 2018 Share Posted December 9, 2018 looks ace mate Link to comment Share on other sites More sharing options...
Ferret90 Posted December 9, 2018 Author Share Posted December 9, 2018 18 hours ago, Fenside MF said: looks ace mate Cheers Jamie Link to comment Share on other sites More sharing options...
Ferret90 Posted December 9, 2018 Author Share Posted December 9, 2018 After looking at the naaaasssty rear hitch I thought I would replace it with an artisan32 one but the prices so, I decided to make my own one, something I've never tried before but it seem to be going well... Link to comment Share on other sites More sharing options...
Ferret90 Posted December 9, 2018 Author Share Posted December 9, 2018 Done Link to comment Share on other sites More sharing options...
Ferret90 Posted December 11, 2018 Author Share Posted December 11, 2018 Painted linkage, some new mirrors, and doing some detail in the cab than now needs painting as well Link to comment Share on other sites More sharing options...
844john Posted December 11, 2018 Share Posted December 11, 2018 It's a slippery slope once you start Ted, just adding a "little" extra detail soon turns into almost a rebuild Link to comment Share on other sites More sharing options...
Ferret90 Posted December 11, 2018 Author Share Posted December 11, 2018 55 minutes ago, 844john said: It's a slippery slope once you start Ted, just adding a "little" extra detail soon turns into almost a rebuild I know exactly what you mean John, you add some detail and the harder you look, the more inaccuracies you see. You either end up with a lovely new tractor or a pile of bits Link to comment Share on other sites More sharing options...
Ferret90 Posted December 13, 2018 Author Share Posted December 13, 2018 Bit more done... Link to comment Share on other sites More sharing options...
