justy 46 Posted August 23, 2020 Share Posted August 23, 2020 Compare.. The TM does sit back...but the cab frame looks the same bar the roof. Link to comment Share on other sites More sharing options...
robbo Posted August 23, 2020 Author Share Posted August 23, 2020 14 hours ago, justy 46 said: The early TM 175 & 190s had their fair share off issues and no dought the bigger MXMs were probably the same. But the smaller ones like the 140 ,120 & 155 are good enough by all accounts. I don't know whether you used to follow the British Farming Forum some years ago but there was an excellent thread on there by Footsfitter called TM175 and the muppets from Basildon which set out all of the problems they had with their 175. Sad to say it was in the workshop more than it was in the field Link to comment Share on other sites More sharing options...
Paul Palmer Posted August 23, 2020 Share Posted August 23, 2020 yes the 175 and 190 suffered problems,not so sure about the smaller ones though Link to comment Share on other sites More sharing options...
Tractorman810 Posted August 23, 2020 Share Posted August 23, 2020 4 hours ago, justy 46 said: Compare.. The TM does sit back...but the cab frame looks the same bar the roof. i doubt theres any real difference between the 30 and tm bar the front wheel size ,which looks bigger on the tm, so pops the front end up, giving the illusion of the cab tipping backwards. when most makers update stuff especially when its more a cosmetic one like those ,they dont remake basic parts, if anything i would say that replicagri have maybe got the cab framing a little short height wise, giving the squat look to it and of course that cab roof. Link to comment Share on other sites More sharing options...
roberthenning Posted August 23, 2020 Share Posted August 23, 2020 The difference between (most) TMs and 60 series cab difference was cab suspension making it sit higher. If the cab setback at rear too much usually the shocks were done. (And cab top on the ones with strips) early tms roof was same. Also early tms had grey chassis and later first gens had black. As said the TMs were pretty bullet proof why they command high prices now. The long wheel base 175s and 190s were troublesome at start but all sorted now and have evolved into lwb T7.270s very good tractors. As for the repliagri abomination it’s as inaccurate as the 8560 ie the bonnet being a bit wide (forgivable) and THAT cab being far too squat, I changed mine for in imber cab. 40s 60s and TMs all had same cab Link to comment Share on other sites More sharing options...
Paul Palmer Posted August 23, 2020 Share Posted August 23, 2020 oh bet that imber cab on the model looks good Robert,any pictures? Link to comment Share on other sites More sharing options...
roberthenning Posted August 23, 2020 Share Posted August 23, 2020 That’s her there. Forgot to paint the wheel centres for whatever reason. Had the pleasure to bounce around in many’s a 60 and tm Link to comment Share on other sites More sharing options...
Paul Palmer Posted August 23, 2020 Share Posted August 23, 2020 thanks Robert Link to comment Share on other sites More sharing options...
Fenside MF Posted August 23, 2020 Share Posted August 23, 2020 I was wanting to get a tm155 in my collection,newer style roof looks too thick and as phil said dashboard is way too big so not sure at all, I'd expect better for the price of them. Link to comment Share on other sites More sharing options...
bluegreen Posted August 24, 2020 Share Posted August 24, 2020 I suspect Toyfarmer will use a fresh CASE MXM bonnet design along with the different CASE roof…..and if the cabs pinched like the TMs I guess it could be modified or "imbered" Link to comment Share on other sites More sharing options...
Tractorman810 Posted August 24, 2020 Share Posted August 24, 2020 4 minutes ago, bluegreen said: I suspect Toyfarmer will use a fresh CASE MXM bonnet design along with the different CASE roof…..and if the cabs pinched like the TMs I guess it could be modified or "imbered" you may get the roof and bonnet, would need to be that at a minimum , but i doubt the design cab will change ,if you go that far down the route it becomes a whole new model, and the costs rocket, i remember someone a while back looking into a new model, tried all the main stream makers, and all of them said getting a cab right, is the hardest part, the finer you go, or more angles you have, the higher the wastage is in rejects, and the model commissioner pays for them, hence why most we see ain't spot on, and look to bulky. Link to comment Share on other sites More sharing options...
justy 46 Posted September 24, 2020 Share Posted September 24, 2020 I see the new Chartres model ..Looks nice. Case IH 856XL and comes with a few extras ..dual wheels and the usual. Link to comment Share on other sites More sharing options...
844john Posted September 25, 2020 Share Posted September 25, 2020 yes please! Link to comment Share on other sites More sharing options...
Tractorman810 Posted September 25, 2020 Share Posted September 25, 2020 already ordered mine, closest yet to a uk spec, Link to comment Share on other sites More sharing options...
844john Posted September 25, 2020 Share Posted September 25, 2020 where have you ordered yours from Sean if you don't mind me asking? Link to comment Share on other sites More sharing options...
FendtFarmer Posted September 25, 2020 Share Posted September 25, 2020 1 hour ago, 844john said: where have you ordered yours from Sean if you don't mind me asking? Might be off use John Link to comment Share on other sites More sharing options...
Tractorman810 Posted September 25, 2020 Share Posted September 25, 2020 few people offering them john, i went for jos at t toys , not much more than that one joe posted, wasnt 100 % sure how many in the uk would get them in , seems a lot lower than normal run as well @ 2000? Link to comment Share on other sites More sharing options...
justy 46 Posted September 25, 2020 Share Posted September 25, 2020 G&M will be getting them in also it seems. But I won't panic. You can be sure more versions will follow.. Link to comment Share on other sites More sharing options...
Tractorman810 Posted September 25, 2020 Share Posted September 25, 2020 not normally other versions with the chartres ones justin , either way its a nice model, have a good few from previous shows already ,so nice to keep the line going, plus they are all normally from the age range i prefer to collect anyway Link to comment Share on other sites More sharing options...
844john Posted September 25, 2020 Share Posted September 25, 2020 Thanks for that lads, must admit i was thinking along similar lines Justin that the face lift models would be following on shortly Link to comment Share on other sites More sharing options...
justy 46 Posted September 25, 2020 Share Posted September 25, 2020 4 hours ago, 844john said: Thanks for that lads, must admit i was thinking along similar lines Justin that the face lift models would be following on shortly If it's anything to go by the early IHs..you will have 2wd versions etc ..im sure.. a 785xl maybe..You know the story . Link to comment Share on other sites More sharing options...
catkom3 Posted September 30, 2020 Share Posted September 30, 2020 Also due 2021 a Kuhn Optimer 303, Regards Joe. Link to comment Share on other sites More sharing options...
