Johny mf Posted September 22, 2007 Posted September 22, 2007 here are some photo's of the MF3125 i am trying to make first some pics off the cab when i started a couple of day's ago Quote
TM190 Posted September 22, 2007 Posted September 22, 2007 what thickness of plastic is that you are using \ Quote
Johny mf Posted September 22, 2007 Author Posted September 22, 2007 i want to make the model on a RENAULT ares from UH this evening i worked on the model and this is how far i came! Cut of the iron tank and another peese that was stukking out the chassis. Made a plastic plate in the hole and made the cab platform fit on the chassis. Quote
Johny mf Posted September 22, 2007 Author Posted September 22, 2007 what thickness of plastic is that you are using \ i use 2mm plastic plate or 3mm plastic plate TM190. The thing is this plate thicknes is easy to bend and to cut whit a nife! The plate is from the brand evergreen. Quote
Lord Ferguson Posted September 22, 2007 Posted September 22, 2007 Hey... thats looking good Johnny... good start so far mate... I look forward to seing this one progress now Quote
ihatepoundland Posted September 22, 2007 Posted September 22, 2007 Oh dear, he's at it again! Do you draw your cabs out free hand and then build them? Quote
Johny mf Posted September 22, 2007 Author Posted September 22, 2007 Hey 1HP i draw them indeed at free hand! but when i got the shape i take a straight peace and i make the ruffley lines straight on paper. take ciscer and cut the shape out from the paper. then i draw the lines around the shaped paper on plastic plate. Take a knife and cut it out the plastic plate! So the lines must be straight i supose \ ( it was verry dificult to explain for me because some english words for things i don't now sometime!) Hope you now how i do it Quote
ihatepoundland Posted September 22, 2007 Posted September 22, 2007 Makes perfect sense to me You have a good eye for proportion using that method, something I do because I'm lazy with other parts is place a 1/32 version on a computer scanner, scan that in and then print that out as a template It may work for the sides of the cab \ Quote
sparrow legs Posted September 22, 2007 Posted September 22, 2007 cant wait to see it finnished, my dad had a 3125, k reg from new, was swapped for a jd 7710 in 1999, 3125 was a beast, had duels all round, top tractor favorate for me! Quote
Johny mf Posted September 24, 2007 Author Posted September 24, 2007 Makes perfect sense to me You have a good eye for proportion using that method, something I do because I'm lazy with other parts is place a 1/32 version on a computer scanner, scan that in and then print that out as a template It may work for the sides of the cab \ wel the thing is that i look at a picture and begin whit rufley lines on paper. Then i make the cab side like i think it is perfect! Till now it worked verry good for me! But there is one thing you should Know! I am a carpenter and work at the construction site making 5 strore buildings! So most people know the line: a carpenters eye! The tip you gave can work but not for me because i am not satisfyd soon! Quote
Johny mf Posted September 24, 2007 Author Posted September 24, 2007 I begon whit the bonnet today! i am already this far! and i was looking off the mirors from the Ares can fit on the cab whit some adjusments Quote
ihatepoundland Posted September 24, 2007 Posted September 24, 2007 It's looking a little high to me, johny , I had a look for a photograph to check; http://www.cervettigroup.com/catalogo/foto/USATE_MACCHINE_AGRICOLE/118.jpg I think if the cab and bonnet were lowered a fair bit, you'd have the makings of a excellent model Quote
Johny mf Posted September 25, 2007 Author Posted September 25, 2007 It's looking a little high to me, johny , I had a look for a photograph to check; http://www.cervettigroup.com/catalogo/foto/USATE_MACCHINE_AGRICOLE/118.jpg I think if the cab and bonnet were lowered a fair bit, you'd have the makings of a excellent model that was what i was thinking to mate Now it looks more like a 3650!! The thing is i want to try to lower the bonnet and the cab \ but its not going to be easy! Quote
Tractorman810 Posted September 25, 2007 Posted September 25, 2007 only way you'll get it lower is prob to cut the top of the chassi arround the cab area, then you can drop the bonnets height, have the same problem with an ongoing convo i am doing, havn't got round to angle grinding the chassis yetm, but the basic parts are made Quote
Deerepower Posted September 25, 2007 Posted September 25, 2007 looking good , why not make this a 3650 then you wont have to lower it Quote
Johny mf Posted September 25, 2007 Author Posted September 25, 2007 can do that but there is one problem i think ,the cab won't vit anymore if i lower it! then the rearfenders laying on the back weels Or i must lower it a couple of mm's Hope to hear what you think of it guy's Quote
Johny mf Posted September 25, 2007 Author Posted September 25, 2007 looking good , why not make this a 3650 then you wont have to lower it that's an option to deere power i begon to think of that also but i don't know what i will do yet! Quote
Tractorman810 Posted September 25, 2007 Posted September 25, 2007 the top of the bonnet looks to big to me height wise, not the cabs position, what about triming the height of the bonnet, the lower half looks right, the upper seems to tall, if that makes sence Quote
Johny mf Posted September 25, 2007 Author Posted September 25, 2007 the top of the bonnet looks to big to me height wise, not the cabs position, what about triming the height of the bonnet, the lower half looks right, the upper seems to tall, if that makes sence i understand tractorman i am going to try to chainge that bonnet or make me a new one! Maybe i buy another Ares and keep the bonnet like it now is and also make a 3650 Quote
Tractorman810 Posted September 25, 2007 Posted September 25, 2007 heres the one i am part way into, havn't really done anything on it for agood few weeks now, as you can see bonnet needs extending and front grill made,the arches are in the right position though, just temp glued on for positioning work but the bonnet to me seems to be the right height side on?? hope it helps, also you can judge how much glass there is on the front screen to, i think because your bonnet is a little to "high" for a better word, the front of the cab looks a little out, so making it appear to small Quote
Johny mf Posted September 25, 2007 Author Posted September 25, 2007 heres the one i am part way into, havn't really done anything on it for agood few weeks now, as you can see bonnet needs extending and front grill made,the arches are in the right position though, just temp glued on for positioning work but the bonnet to me seems to be the right height side on?? hope it helps, also you can judge how much glass there is on the front screen to, i think because your bonnet is a little to "high" for a better word, the front of the cab looks a little out, so making it appear to small i know what you mean sean but there is one thing about my convo and youre convo Here is the thing i making mine on a ares chassis and you are making youre's on a celtis chassis! Don't mean to be rude or saying that youre convo is not good i think that i better can make my convo a 3650! And try to make the 3125 another time on a celtis chassis!(if you know what i mean ) Quote
Tractorman810 Posted September 25, 2007 Posted September 25, 2007 yeah know what you mean mate, no point wasting all the good work you have done is there, only went for the celtis chassis this end as i wanted a smaller 3100 series to pair up with my 3070's and 3690, a nice mid ranger so to speak Quote
Johny mf Posted September 25, 2007 Author Posted September 25, 2007 yeah know what you mean mate, no point wasting all the good work you have done is there, only went for the celtis chassis this end as i wanted a smaller 3100 series to pair up with my 3070's and 3690, a nice mid ranger so to speak what type is it going to be sean If i am corectly the 3125 is not much longer then a 3080/3090/3085/3095 I think i choose for the same chassis as you if i make the 3125! Quote
Tractorman810 Posted September 25, 2007 Posted September 25, 2007 not 100%decided yet to be honest, just one mid range of my current 3000's i have, mind you got more parts ordered for it yet Quote
