A ploeger is born!!
  • Replies 376
which ones mine??? the one with the flat tyre??? im gonna put a number one on the ploeger and and a number 2 on the pmc when i get them :)im so sad ::) ::)::)
couldnt possibly comment ::) ::)
No, thats the final machine as they will all be from now on.... a few slight modifications to the original one I posted last week.
That one just needs the lights painting on and a couple of other bits doing which you can't see.  ;)
whats the final number then you have created? you should have put the numbers on them 1-?? like they have in the gangs
how eva i havent ever seen more than 4 in a gang so ......
Nine spoken for so far.  :o
he sells them. if he has any left you may be able to obtain one lets just say the one on ebay went very cheap!!!!
what was the final price so i dont have to go looking for the link  ???
We run two of the ploegers, the detail on the model is amazing, the only differece i can see is that the rear wheels look a little narrow, ours are about 2 feet wide at the back and a little wider at the front.  A farm near me has 6 PMC, they look like a swarm of bees hovering over a field.
Correct... unfortunately i couldn't get any decent wheels that were the right size both widthways and diameter, so I stuck with the original ones from the axle which were near enough the right diameter but a bit too narrow.  :)
I've had to loose some of the other detail on the machine to make it work from a moulding perspective also.  :)
Where are you based Sipher??
the price on ebay was ?150 plus P&P of about ?15 which was cheap for the standard of model  ;D ;D ;D not that im trying to plug them or anything ;)
Due to the weight of these and the packing required, its borderline either ?9 or ?19 (approx) for postage by special delivery depending on what packing I use.
i'll pick up then  ;) ;)
