Tractorman810 Posted April 22, 2020 Share Posted April 22, 2020 I assume the glue issues due ti the paint where you wanted to bond in? Not an easy way round that one, i have used some humbrol mask paint before, covered the area sprayed up then removed, just had to touch the joins up with a small brush after, great build mind look good once all piped up as well Link to comment Share on other sites More sharing options...
L33 DA17ON Posted April 22, 2020 Share Posted April 22, 2020 That looks fantastic mate. Good work. It looked a tedious job. But great that you took a load of detailed pictures for us to see. Great work well done. Link to comment Share on other sites More sharing options...
sipher172 Posted April 22, 2020 Author Share Posted April 22, 2020 3 hours ago, Tractorman810 said: I assume the glue issues due ti the paint where you wanted to bond in? Not an easy way round that one, i have used some humbrol mask paint before, covered the area sprayed up then removed, just had to touch the joins up with a small brush after, great build mind look good once all piped up as well It was strange, some areas glued fine others had issues. In the end I filed the paint off and then glued. I had to hold each section 20~30 seconds, where as the glue normally fixes in 1~2 seconds if pressure is applied. I have often found that some pieces of plastic just dont want to glue. My assumption was that there is layer of oil, grease, etc on the surface that limits the bond. Link to comment Share on other sites More sharing options...
sipher172 Posted April 22, 2020 Author Share Posted April 22, 2020 2 hours ago, L33 Da17on said: That looks fantastic mate. Good work. It looked a tedious job. But great that you took a load of detailed pictures for us to see. Great work well done. Thanks. I always learn a lot from everyone else in progress pictures, so for all of my builds I try to share as much as possible to try to reciprocate. Link to comment Share on other sites More sharing options...
sipher172 Posted April 25, 2020 Author Share Posted April 25, 2020 Made a few tweaks to allow it to fold easier. I have tested it setup in a field as well. I have ordered some wire for pipes, might not arrive for a while. Then I will have to print some decals. Link to comment Share on other sites More sharing options...
Stabliofarmer Posted April 25, 2020 Share Posted April 25, 2020 Very impressive build! All the pipes should take it to the next level, looking forward to seeing the finished piece. A serious level of patience so far! Link to comment Share on other sites More sharing options...
844john Posted April 26, 2020 Share Posted April 26, 2020 That is looking really well, a credit to your skill and patience! I know what you mean about the glue and varying bonding times as I've found the same, funny thing is, no matter how oily or greasy my hands are the superglue never fails to stick me to the part that I'm holding whilst waiting for it to bond! Link to comment Share on other sites More sharing options...
jmd Posted April 26, 2020 Share Posted April 26, 2020 haha always happens to me that john never fails to stick to my fingers Link to comment Share on other sites More sharing options...
sipher172 Posted April 26, 2020 Author Share Posted April 26, 2020 I am definitely a pro at sticking my fingers together, haha. Thanks for the comments Link to comment Share on other sites More sharing options...
SPN Posted April 26, 2020 Share Posted April 26, 2020 That is a cracker. Well done. Link to comment Share on other sites More sharing options...
sipher172 Posted May 24, 2020 Author Share Posted May 24, 2020 adding the first seed tubes. 10 down, 86 to go. Link to comment Share on other sites More sharing options...
FendtFarmer Posted May 24, 2020 Share Posted May 24, 2020 27 minutes ago, sipher172 said: adding the first seed tubes. 10 down, 86 to go. Even adding those few makes a massive difference Chris! What you used for the pipes? Link to comment Share on other sites More sharing options...
sipher172 Posted May 24, 2020 Author Share Posted May 24, 2020 10 minutes ago, FendtFarmer said: Even adding those few makes a massive difference Chris! What you used for the pipes? It is 0.5mm white wire. Link to comment Share on other sites More sharing options...
pistol pete Posted May 24, 2020 Share Posted May 24, 2020 very tidy, a lot of work has gone into that. looks tidy behind the deere Link to comment Share on other sites More sharing options...
sipher172 Posted May 27, 2020 Author Share Posted May 27, 2020 96 seed tubes attached. Now just got to tidy them up and plumb them into the tank. Link to comment Share on other sites More sharing options...
sipher172 Posted May 30, 2020 Author Share Posted May 30, 2020 Managed to get all the pipes plumb together, was a bit of a mission. Still got the main pipes from the tank to add along with the decals. Link to comment Share on other sites More sharing options...
JEP Posted May 30, 2020 Share Posted May 30, 2020 Great build, and fantastic attention to detail! Well done. Link to comment Share on other sites More sharing options...
Stabliofarmer Posted June 11, 2020 Share Posted June 11, 2020 Phenomenal! Just wow, I think that would have really tried anyone's patience Link to comment Share on other sites More sharing options...
