mb86 Posted December 19, 2015 Share Posted December 19, 2015 57 minutes ago, SPN said: We've seen the success of the UH and NOREV classic CLAAS combines. I think there would surely be a demand for classic Claes/Clayson/NH combines from the M103 right up to the TX series. I'd love to see an 8100 and a 7400 in 1:32, but both were niche models in their day, so not sure how much demand there would be for them in model form. It seemed like every other combine was a NH in the 80s so I'm certain there would be demand. I was thinking 81/82 from replicagri as they were aimed at the French market just like the 7400 and 7910 (which is also like them to produce!) Link to comment Share on other sites More sharing options...
justy 46 Posted December 20, 2015 Share Posted December 20, 2015 On 12/19/2015 at 6:31 PM, mb86 said: It seemed like every other combine was a NH in the 80s so I'm certain there would be demand. I was thinking 81/82 from replicagri as they were aimed at the French market just like the 7400 and 7910 (which is also like them to produce!) The 7400 was a very rare tractor.. Even in France & Beligum .. I remember 2 Fritzmeir cabbed 74s around localy years ago.. One contractor had one on a NH 717 Chopper backed up by a few 76s & 66s carting.. If Replicagre were to do Fords .. could see them early 6cyl Fords being done alright.. A 7910 & 8210 are much the same & both could be done on the same tooling...But the 81 is the one I would crave for the most & I reckon the classic NH combines will eventually surface from ether UH, ROS or Replicagri.. Link to comment Share on other sites More sharing options...
mb86 Posted December 20, 2015 Share Posted December 20, 2015 53 minutes ago, justy 46 said: The 7400 was a very rare tractor.. Even in France & Beligum .. I remember 2 Fritzmeir cabbed 74s around localy years ago.. One contractor had one on a NH 717 Chopper backed up by a few 76s & 66s carting.. If Replicagre were to do Fords .. could see them early 6cyl Fords being done alright.. A 7910 & 8210 are much the same & both could be done on the same tooling...But the 81 is the one I would crave for the most & I reckon the classic NH combines will eventually surface from ether UH, ROS or Replicagri.. I didn't realise there were any 74s this side of the channel. Do you know if those were imported by the owners? A 79 is just a non turbo 82 isn't it? Link to comment Share on other sites More sharing options...
SPN Posted December 21, 2015 Author Share Posted December 21, 2015 2 hours ago, mb86 said: I didn't realise there were any 74s this side of the channel. Do you know if those were imported by the owners? A 79 is just a non turbo 82 isn't it? There was a Ford dealer in Ireland (I think it was Armstrongs) who used to import Q cab 7400s. I remember the ad in the Farmers Journal when I were a lad. I've never seen a Fritz 7400. Truly the forerunner to the 7810. The 7910 and 8210 are both derated TW5s mated to 7710 back ends. The same tractor with a different tweak to the fuel pump. Link to comment Share on other sites More sharing options...
mb86 Posted December 21, 2015 Share Posted December 21, 2015 8 hours ago, SPN said: There was a Ford dealer in Ireland (I think it was Armstrongs) who used to import Q cab 7400s. I remember the ad in the Farmers Journal when I were a lad. I've never seen a Fritz 7400. Truly the forerunner to the 7810. The 7910 and 8210 are both derated TW5s mated to 7710 back ends. The same tractor with a different tweak to the fuel pump. I bet the 7400's were a beast in their day. Probably still a useful tractor. They would be the forerunner to the 8100 wouldn't they. I thought 79 and 82's preceded the tw 5's which were brought in with the force II range and also had the non load bearing block and used chassis rails like the rest I the t dubs unlike the 82 and 79's Link to comment Share on other sites More sharing options...
justy 46 Posted December 21, 2015 Share Posted December 21, 2015 12 hours ago, SPN said: There was a Ford dealer in Ireland (I think it was Armstrongs) who used to import Q cab 7400s. I remember the ad in the Farmers Journal when I were a lad. I've never seen a Fritz 7400. Truly the forerunner to the 7810. The 7910 and 8210 are both derated TW5s mated to 7710 back ends. The same tractor with a different tweak to the fuel pump. To be honest ... I think half the Fords in Ireland back then were imported from Beligum . Fritz 7A Fords were as common as Q crabbed ones.. Probably depended on the dealer.. I know of lots of secondhand Fords also imported from the UK by Ford dealers. Our own 4000 came from a large estate in England secondhand threw Coleman's in Millstreet . Link to comment Share on other sites More sharing options...
SPN Posted December 21, 2015 Author Share Posted December 21, 2015 3 hours ago, mb86 said: I bet the 7400's were a beast in their day. Probably still a useful tractor. They would be the forerunner to the 8100 wouldn't they. I thought 79 and 82's preceded the tw 5's which were brought in with the force II range and also had the non load bearing block and used chassis rails like the rest I the t dubs unlike the 82 and 79's I don't have my copy of the New Testament with me, so I can't say for definite, but my recollection is that the TW5 replaced the TW10, the TW15 replaced the TW20, and the TW25 was a new model. I also think the 7400 and 8100 used a truck engine, whereas the 7810, 7910 and 8210 used the TW engine. Link to comment Share on other sites More sharing options...
SPN Posted December 21, 2015 Author Share Posted December 21, 2015 2 hours ago, MadMark said: 7400: 2714E engine mated to 6600 backend (I take it the engine was also a Dorset truck engine) 8100: 2715E Dorset truck engine mated to 6700 backend 7910 had a de-rated 8210 engine 8210 was a 8200 but incorporation of series 10 features with a little more power and ZF front axle and made "in house" rather than County making it. TW5 was a rebadged TW10 and only done in 2wd for north America TW15 was a TW20 with de-rated engine to 143 bhp instead of 153 bhp TW25 had a TW20 engine with injection pump re-calibrated to increase fuel flow to 163 bhp Info from the New Testament ...... and we hope that Replicagri make them all. (getting quickly back on topic ) Link to comment Share on other sites More sharing options...
justy 46 Posted December 21, 2015 Share Posted December 21, 2015 3 hours ago, MadMark said: 7400: 2714E engine mated to 6600 backend (I take it the engine was also a Dorset truck engine) 8100: 2715E Dorset truck engine mated to 6700 backend 7910 had a de-rated 8210 engine 8210 was a 8200 but incorporation of series 10 features with a little more power and ZF front axle and made "in house" rather than County making it. TW5 was a rebadged TW10 and only done in 2wd for north America TW15 was a TW20 with de-rated engine to 143 bhp instead of 153 bhp TW25 had a TW20 engine with injection pump re-calibrated to increase fuel flow to 163 bhp Info from the New Testament That about sums it up alright.. Please please please an 8100 for the next 6cyl Ford to be realised... Link to comment Share on other sites More sharing options...
mf135 Posted December 31, 2015 Share Posted December 31, 2015 On 17 December 2015 at 11:55 AM, valtrajohnie said: Finaly is it coming the normal version of the Renault TX Renault TX 133-14 € 44,90 Available: unknowing Sourch: pur-tracteur-passion.com Great to see the 133-14 tx being made as had two of these in the passed in real not a bad tractor the MWM engine would lug very well. Not being fussy but were is the fuel filler cap? As in real it was on top of the bonnet great to fill in the field with cans not! good old days! Link to comment Share on other sites More sharing options...
Lexion580 Posted August 13, 2016 Share Posted August 13, 2016 Has anyone purchased the 1640 Axial Flow? What are your thoughts on the quality? Some of the photos I've seen shows the reel is poorly made?, also can the header be put on the optional header trailer that they sell? Link to comment Share on other sites More sharing options...
ertlerik Posted August 13, 2016 Share Posted August 13, 2016 7 hours ago, Lexion580 said: Has anyone purchased the 1640 Axial Flow? What are your thoughts on the quality? Some of the photos I've seen shows the reel is poorly made?, also can the header be put on the optional header trailer that they sell? Super quality, header fits on the trailer, almost perfect, corn header should have bin 6 row and top of the grainbin should not have a lid on imo Link to comment Share on other sites More sharing options...
alf aphid Posted August 17, 2016 Share Posted August 17, 2016 On 13 August 2016 at 4:11 PM, ertlerik said: Super quality, header fits on the trailer, almost perfect, corn header should have bin 6 row and top of the grainbin should not have a lid on imo Agreed, I now have both versions and have to say, like all replicagri stuff, they are top notch, you will not be disappointed Link to comment Share on other sites More sharing options...
