Cerin's Ferguson Te-20 --- Flossie , Massey Ferguson 165 And Nuffield DM4?
Massey Boy
  • Replies 116
right mr.C,.........whats puzzling me is that box affair at the front of the plough, have never seen anything like that, and imagine flossies arms attached to the lower pins,..............right,......how the heck is that square box going to fit between her arms .Its going to be pretty tight in there; the front of the plough is going to be nearly touching her ar*e end, ........if you see what I mean............ ;) ........... ???
yeah its confusing, but it must be for some sort of tractor as its got the bars for the link arms but not reali much for the top link :-\
cerin i think your plough might be a randsome but its not fixed via 3 point link age but towed and where it looks like it fixes to the 3 point link age is where wheels go to control the depth i will cheek with my brother in law as he probly had one from new
going by the small amount of paint left on it ,it could be a fisher humphries plough. some implements used behind david browns used four point linkage i believe. any david brown fans on here know?
I'll send this link to Tim (Powerrabbit).. he's a David Brown specialist.. and a hugely knowledgeable chap as well
GOOD MAN  I KNOW DB USED CONVERGING  THREE POINT LINKAGE , BUT BELIEVE SOME IMPLEMENTS USED TWO TOP LINKS. THE LACK OF DEPTH WHEEL ON THE PLOUGH IS PUZZLING
Sorry chaps and chapesses, I've not been following this topic for a while but thanks to Mark I'm now up to speed with it. Anyway, looks to me like a Ransomes plough that has several parts missing so hard to tell wheather it was a three-point mounted or a trailed plough. If the 'cross-shaft' is in the correct position, it is too far back the frame and any lift arms would never reach it but, as said, it could be that there should be a couple of iron spoked wheels on it and the ends being cranked, like on a normal mounted plough for the arms, would make more sense as when the plough is in work, you would wind in the sideways 'handle' (or out) to level up the plough for even depth furrows. There is no 'lift' mechanism on it that would consist of an eccentric 'dog' plate and a lift handle that would come under the 'axle' to lift the plough out of work or any drawbar hitch mechanism. If ever anyone sees a similar plough complete, it would be a good idea to post up a picture for comparison. As for David Brown ploughs being 'four-point linkage', I see where you're coming from, I think you may be visualising the early 3-point linkage plough on the VAK1 up to the Cropmaster where there was another link mechanism bolted to the left lift arm with a winding handle on it that connected to a lug on the cross-shaft for ajusting the width of the front furrow. This was discontinued around 1950 when the next model of plough had both depth/land wheel and the cross-shaft ajustment winding handles mounted on the plough headstock.
You guys are amazing! Am I right in saying then it's a kind of 'bodge job'? Would people have converted their ploughs to what they had available to pull them?
Yes most certainly they did. The plough for my Nuffield was converted from a trailing plough to a lift plough I was told by my uncle who used to drive my Nuffield and plough with this plough and a Newlands one he had.
When hydraulic lift began to appear on tractors in the late 1940's, because of the War there were no ploughs being made with hydraulic lift coupling and the farmers still had their old trailed horse and tractor drawn ploughs, new ploughs were not being manufactured because of the shortage of iron but plough shares and wearing plough parts were as we still had to till the land to feed the nation and it was some time before ploughs were manufactured for 3-point linkage so when tractor lift did arrive, a lot of farmers had their trailed ploughs converted to lift and this was invariably carried out by the local blacksmith who also did the majority of farm machinery repairs and fabrications and in doing this for farmers later led to the natural progression of the blacksmith supplying farm machinery and later on tractors, this is when dealerships and agricultural suppliers started to spring up. I bet that anyone who looks far enough back into their local dealers history that their predecessors started their buisness as blacksmiths.
Thanks very much everyone for the info and help :)
But it dosnt look like i will be ploughing any time soon  :D
done a bit of research on ploughs found out there was a company called s m wilmot from bristol. they produced a quick -adjustable plough. its believed it bolted to the tractor with hinge? and quote had hydraulic ram to hasten its entry into the ground. a screw handle made it a simple matter to set the furrow width between 9 and 12 inches in no time at all.  unfortunately there are no pictures >:( . does your plough have holes for lynch pins on end of crossshaft?.
  • 4 months later...
Yes it did, but it dosnt matter now as some one took that plough  :of
I got a proper fergy one now  ;)
Just a littel update, got flossie out today and shes still going might have to split her at some point as the clutch is a bit dodgy but other than that alls good!
