SPN Posted July 17, 2020 Share Posted July 17, 2020 That is really coming along well. Some excellent detailing there. Link to comment Share on other sites More sharing options...
smithy Posted July 17, 2020 Share Posted July 17, 2020 You have done a grand job ,lots of small details that would normally be missed out ,the blue water pipe is one of them ,well done Link to comment Share on other sites More sharing options...
L33 DA17ON Posted July 18, 2020 Author Share Posted July 18, 2020 On 7/17/2020 at 3:32 PM, Daniele said: Wowowowow I needed this to inspire me... I d like to start with the big house and then do the rest... So you do the frame of wood and then glue the painted cardboard on it to give the desire wall effect is that right? No not really no cardboard used. On the sheds I've scrapped the house now as It was a little out of proportion and couldn't fit if all on the display. So the byre is 6mm ply just what I've been using to board the roof out in my attick it's just the off cuts. Get the ply to size and do all the cuts first then glue them all together to get the frame. Then I added the roof timbers and treated them with wood stain. For the stone wall affect I used gray tile grouting it's the flexible stuff. I just covered the walls and left it over night. Next day I just marked out the coin stones and then scribed the stone walls courses.. if you need any more info I'll be happy to help. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted July 18, 2020 Author Share Posted July 18, 2020 20 hours ago, smithy said: You have done a grand job ,lots of small details that would normally be missed out ,the blue water pipe is one of them ,well done Thank you. Hoping to do a little more but as my sons going to Singapore for treatment I'll be going over there for upto a year so itll be on hold for a while soon. Link to comment Share on other sites More sharing options...
Daniele Posted July 19, 2020 Share Posted July 19, 2020 13 hours ago, L33 DA17ON said: No not really no cardboard used. On the sheds I've scrapped the house now as It was a little out of proportion and couldn't fit if all on the display. So the byre is 6mm ply just what I've been using to board the roof out in my attick it's just the off cuts. Get the ply to size and do all the cuts first then glue them all together to get the frame. Then I added the roof timbers and treated them with wood stain. For the stone wall affect I used gray tile grouting it's the flexible stuff. I just covered the walls and left it over night. Next day I just marked out the coin stones and then scribed the stone walls courses.. if you need any more info I'll be happy to help. Greeeeat, thank you very much....I m starting to cut out the frames now, I ll see how I get on, if needed , and I may do, I ll give u a shout... thanks a lot Link to comment Share on other sites More sharing options...
L33 DA17ON Posted July 21, 2020 Author Share Posted July 21, 2020 Fitted some halogen strip lights and cables light switches. Just a little more detail added. Link to comment Share on other sites More sharing options...
Daniele Posted July 21, 2020 Share Posted July 21, 2020 21 minutes ago, L33 DA17ON said: greeeeeatttttt , I started my project, not sure if u ve seen my post on here ( in which I have thanked you for the inspiration ) Link to comment Share on other sites More sharing options...
L33 DA17ON Posted July 22, 2020 Author Share Posted July 22, 2020 12 hours ago, Daniele said: Haven seen the post I was away warping silage lastnight till early hours in the morning. I'll go have a look. Link to comment Share on other sites More sharing options...
Mike R Posted July 22, 2020 Share Posted July 22, 2020 Coming along nicely. Link to comment Share on other sites More sharing options...
F8N Posted July 22, 2020 Share Posted July 22, 2020 Awesome peice of work Link to comment Share on other sites More sharing options...
L33 DA17ON Posted July 24, 2020 Author Share Posted July 24, 2020 Another shed started on Greenside. Got the doorways window and size of the shed sorted. This yard that sits just above the big cow shed, its used for new born calfs for a few weeks then hopefully turn them out onto the front fields. But the last two winters my brother has been keeping the Longhorns in there to house them over winter. Just gives then the run of the sheds and yard. With a ring feeder just behind the wall. Itll be almost the same as the byre that I've done with stone work and doors. Just different inside. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 1, 2020 Author Share Posted August 1, 2020 Got the small calving sheds white washed inside and got the exterior walls coated in grout. Not looking forward scratching out the stone work. I got blisters on the last one. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 3, 2020 Author Share Posted August 3, 2020 Got a start on the stonewalls lastnight, had to stop as my finger was staring to go numb. Seems a little lighter this one used the same grouting. Hopefully get the stonewalls finished tonight then I can start on the wood work. Had a quick mockup of a old hay rack I'll see what it looks like when sprayed up and rust added. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 4, 2020 Author Share Posted August 4, 2020 Stone work finished off tonight now I can move on to the wood work. More enjoyable than sitting scraping the stone work out. Link to comment Share on other sites More sharing options...
fordmajor Posted August 5, 2020 Share Posted August 5, 2020 Are u using balsa for doors n frames. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 5, 2020 Author Share Posted August 5, 2020 4 hours ago, fordmajor said: Are u using balsa for doors n frames. Its along those lines it's just cls 4x2 timbers that I've cut in the garage on the bid saw I cut loada of different sizes. Little bit fiddly with a big saw but its cost nothing as its scrap wood that's left over. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 7, 2020 Author Share Posted August 7, 2020 Started the shed doors slow work but getting there. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 13, 2020 Author Share Posted August 13, 2020 Very little to update on Greenside. Finding it hard to get time in the loft. I got a quick hour the other night so got the shed doors finished off painted and latches on and painted. I'll start the roof timbers next. dont take any notice of that house I was just using it to see how wide I could make the road up into the yard above. I still need to build the door on the corner shed but this will be box section with tin sheet Link to comment Share on other sites More sharing options...
Daniele Posted August 14, 2020 Share Posted August 14, 2020 Wow, bet loads of patience has gone into building them doors. outstanding effort Link to comment Share on other sites More sharing options...
844john Posted August 14, 2020 Share Posted August 14, 2020 Looking very well Lee! Link to comment Share on other sites More sharing options...
Valley Axe Man Posted August 15, 2020 Share Posted August 15, 2020 Good to see your still getting a bit of progress Lee, i know your mind will be else where with your lad an trying to get him sorted, but getting on the farm for an hour or so will give you a distraction and keep you sane Link to comment Share on other sites More sharing options...
Stabliofarmer Posted August 15, 2020 Share Posted August 15, 2020 Coming together nicely Lee, loving the little details like the strip lights and latches. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 16, 2020 Author Share Posted August 16, 2020 On 8/15/2020 at 8:45 AM, Valley Axe Man said: Good to see your still getting a bit of progress Lee, i know your mind will be else where with your lad an trying to get him sorted, but getting on the farm for an hour or so will give you a distraction and keep you sane Thanks mate yeah its stopping me going insane. Had the long journey down to Heathrow today as my boy got the all clear to fly to Singapore for the medical treatment he needs but only mam and Stanley can go for now me and my 4year old daughter will have to wait not sure how long of a wait. Find my self doing different little bits and plodding on with it. Link to comment Share on other sites More sharing options...
L33 DA17ON Posted August 16, 2020 Author Share Posted August 16, 2020 20 hours ago, Stabliofarmer said: Coming together nicely Lee, loving the little details like the strip lights and latches. Thanks made would be nice if they worked but that'll do for details for now. I'm pleased with how it's going for now. Link to comment Share on other sites More sharing options...
mb86 Posted August 17, 2020 Share Posted August 17, 2020 Your layout is looking great Lee. I like the little details you are adding to the byres like the blocked up windows. Would it be easier on your hands to scribe the stonework while the grout is still slightly soft, although you might not get such a clean cut. Link to comment Share on other sites More sharing options...
