Ferret90 Posted February 15, 2020 Author Share Posted February 15, 2020 Link to comment Share on other sites More sharing options...
Stabliofarmer Posted February 15, 2020 Share Posted February 15, 2020 Simply fantastic Ted, alot of hard work, but we'll worth it for the final result Link to comment Share on other sites More sharing options...
Ferret90 Posted February 16, 2020 Author Share Posted February 16, 2020 22 hours ago, Stabliofarmer said: Simply fantastic Ted, alot of hard work, but we'll worth it for the final result Thank you James , yes getting there just 1 more side Link to comment Share on other sites More sharing options...
Ferret90 Posted February 29, 2020 Author Share Posted February 29, 2020 Making some wooden fences. Nearly finished the granary as well Link to comment Share on other sites More sharing options...
Kirely Posted February 29, 2020 Share Posted February 29, 2020 Exquisite in concept and outcome Link to comment Share on other sites More sharing options...
F8N Posted March 1, 2020 Share Posted March 1, 2020 It's brilliant Link to comment Share on other sites More sharing options...
Ferret90 Posted March 1, 2020 Author Share Posted March 1, 2020 On 2/29/2020 at 3:28 PM, Kirely said: Exquisite in concept and outcome Cheers Kieran 21 hours ago, F8N said: It's brilliant Thank you Gary Link to comment Share on other sites More sharing options...
Ferret90 Posted March 22, 2020 Author Share Posted March 22, 2020 Trying out a bit of lighting, using 12v dolls house stuff with a plug not a battery and a train set controller to dim the lights... Link to comment Share on other sites More sharing options...
Ferret90 Posted March 22, 2020 Author Share Posted March 22, 2020 Managed to get some of the lights in the barns, seems to be working well , only problem is the bulbs get hot... Link to comment Share on other sites More sharing options...
Tractorman810 Posted March 23, 2020 Share Posted March 23, 2020 looks good, but as you mentioned a bit worrying that they get hot with all the plastic around them is that normal, or could it be due to running through the tail transformer you mentioned maybe? to many amps through them poss .have to say the 99 p xmas ones i got don't, and are plenty bright enough, even the yellow light ones, managed to get another pack this xmas gone as well, down side is they run on 2 aa batteries, but i dont have power in the loft bar the lights anyway Link to comment Share on other sites More sharing options...
fordmajor Posted March 23, 2020 Share Posted March 23, 2020 1.5 to 3v leds dont run hot . You can get them in various shades n very good value for money. [ bright components ] should cover all your needs. I use then for flashing warning lights on tractor cabs . powered by flat sell batteries from the £ shop 8 for a quid. Link to comment Share on other sites More sharing options...
Ferret90 Posted March 23, 2020 Author Share Posted March 23, 2020 11 hours ago, Tractorman810 said: looks good, but as you mentioned a bit worrying that they get hot with all the plastic around them is that normal, or could it be due to running through the tail transformer you mentioned maybe? to many amps through them poss .have to say the 99 p xmas ones i got don't, and are plenty bright enough, even the yellow light ones, managed to get another pack this xmas gone as well, down side is they run on 2 aa batteries, but i dont have power in the loft bar the lights anyway 4 hours ago, fordmajor said: 1.5 to 3v leds dont run hot . You can get them in various shades n very good value for money. [ bright components ] should cover all your needs. I use then for flashing warning lights on tractor cabs . powered by flat sell batteries from the £ shop 8 for a quid. Ive found if I turn the voltage down a bit the don’t get nearly as hot as before they were heating the stuff around the bulb which is not a problem if they are hanging, but definitely a worry in the roof of the granary which is made of balsa wood I think I’ve sorted it though. The thing with batteries is that I would ever turn them on as it would mean replacing them. Link to comment Share on other sites More sharing options...
Tractorman810 Posted March 23, 2020 Share Posted March 23, 2020 25 minutes ago, Ferret90 said: Ive found if I turn the voltage down a bit the don’t get nearly as hot as before they were heating the stuff around the bulb which is not a problem if they are hanging, but definitely a worry in the roof of the granary which is made of balsa wood I think I’ve sorted it though. The thing with batteries is that I would ever turn them on as it would mean replacing them. at least you know what the issue is now, do they do a proper transformer for the lights then? could be worth getting one,save burning them out early then . Link to comment Share on other sites More sharing options...
Ferret90 Posted March 25, 2020 Author Share Posted March 25, 2020 On 3/23/2020 at 9:32 PM, Tractorman810 said: at least you know what the issue is now, do they do a proper transformer for the lights then? could be worth getting one,save burning them out early then . Yes I have a fair idea , I bought the lights in a kit with a 12v transformer but they forgot to put in an adaptor from the transformer to the lighting plugs so I thought I would rig up a train controller. The problem was that the controller lowered it by 4v even on maximum so the lights were really dim ( running 8 v). Then I put a 16v transformer on so it would actually be 12v powering the lights which is what they should be but like I say their just running a bit hot but on 10/11v they seem like be fine Link to comment Share on other sites More sharing options...
F8N Posted March 25, 2020 Share Posted March 25, 2020 Lights add a class touch to an already class dio Link to comment Share on other sites More sharing options...
Ferret90 Posted March 25, 2020 Author Share Posted March 25, 2020 8 hours ago, F8N said: Lights add a class touch to an already class dio Cheers Gary very kind of you Link to comment Share on other sites More sharing options...
Stabliofarmer Posted March 25, 2020 Share Posted March 25, 2020 Love it Ted, creates a really nice atmosphere, and highlights the level of detail you have in the interiors. Particularly like way the plug socket is wired along the beams in granary. Link to comment Share on other sites More sharing options...
Stabliofarmer Posted March 25, 2020 Share Posted March 25, 2020 On 2/9/2020 at 2:06 PM, Ferret90 said: Just looking through on a laptop rather than a phone for once and noticing all sorts of detail. Love the use of black lines to give the look of the brickwork cracking apart. It's clear so much though has gone into every step. Link to comment Share on other sites More sharing options...
Ferret90 Posted March 25, 2020 Author Share Posted March 25, 2020 2 hours ago, Stabliofarmer said: Just looking through on a laptop rather than a phone for once and noticing all sorts of detail. Love the use of black lines to give the look of the brickwork cracking apart. It's clear so much though has gone into every step. Thanks James, I’m working on a thatched cottage which I haven’t started yet but I’m hoping to try and do the same stonework, bet I won’t be able to do it the same though Link to comment Share on other sites More sharing options...
Ferret90 Posted April 10, 2020 Author Share Posted April 10, 2020 Having a go at wrapped silage bales using foam pipe lagging, insulation tape and black bags and then spraying them satin/ gloss. Seen a few different ways of doing them but I’m quite pleased with how they’ve turned out. Got more to do but plenty of time Link to comment Share on other sites More sharing options...
CX820Joe Posted April 10, 2020 Share Posted April 10, 2020 They look spot on. Link to comment Share on other sites More sharing options...
Tractorman810 Posted April 10, 2020 Share Posted April 10, 2020 have to make a few sagged ones for the bottom of the pile, or the odd corner in the yard just rotting away Link to comment Share on other sites More sharing options...
Ferret90 Posted April 10, 2020 Author Share Posted April 10, 2020 10 hours ago, CX820Joe said: They look spot on. Cheers Joe Link to comment Share on other sites More sharing options...
Ferret90 Posted April 10, 2020 Author Share Posted April 10, 2020 7 hours ago, Tractorman810 said: have to make a few sagged ones for the bottom of the pile, or the odd corner in the yard just rotting away Here you go Sean , got a sagged one and a spilt mouldy old one Link to comment Share on other sites More sharing options...
alf aphid Posted April 10, 2020 Share Posted April 10, 2020 They look brilliant ted, the best I’ve seen Link to comment Share on other sites More sharing options...
