Stabliofarmer Posted December 18, 2019 Share Posted December 18, 2019 Both the Stone work and the roofing look spot on Ted, some incredible work on the go! Link to comment Share on other sites More sharing options...
Ferret90 Posted December 21, 2019 Author Share Posted December 21, 2019 On 12/18/2019 at 3:18 PM, Stabliofarmer said: Both the Stone work and the roofing look spot on Ted, some incredible work on the go! Cheers James Link to comment Share on other sites More sharing options...
Ferret90 Posted December 23, 2019 Author Share Posted December 23, 2019 Ive done the kneelers and coping and made a small barn out on the side... Link to comment Share on other sites More sharing options...
Pete Posted December 23, 2019 Share Posted December 23, 2019 Detail is amazing Link to comment Share on other sites More sharing options...
Stabliofarmer Posted December 23, 2019 Share Posted December 23, 2019 Stunning you wouldn't think the Stone was plastic sheet, you've avoided any repetition too which often occurs with plastic sheet. What have you used for tiles in the end? They look very effective Link to comment Share on other sites More sharing options...
Ferret90 Posted December 23, 2019 Author Share Posted December 23, 2019 29 minutes ago, Pete said: Detail is amazing Cheers Pete Link to comment Share on other sites More sharing options...
Ferret90 Posted December 23, 2019 Author Share Posted December 23, 2019 14 minutes ago, Stabliofarmer said: Stunning you wouldn't think the Stone was plastic sheet, you've avoided any repetition too which often occurs with plastic sheet. What have you used for tiles in the end? They look very effective Thanks James , I used card painted different shades of grey then cut into tiles. The only problem is when they are on the roof , I have to touch in the ends of them. also, I didn't measure them when I was cutting them up so if one wasn't quite long enough it would throw everything out from there up Link to comment Share on other sites More sharing options...
Stabliofarmer Posted December 23, 2019 Share Posted December 23, 2019 Looks great, and sounds easier than trying to paint them different colours after applying them. Gives a nice random effect, and the mish mash slates help add to that. Link to comment Share on other sites More sharing options...
dave the farmer Posted December 24, 2019 Share Posted December 24, 2019 Looks great. Link to comment Share on other sites More sharing options...
Ferret90 Posted December 24, 2019 Author Share Posted December 24, 2019 1 hour ago, dave the farmer said: Looks great. thank you David Link to comment Share on other sites More sharing options...
Ferret90 Posted January 13, 2020 Author Share Posted January 13, 2020 Building a workshop/ barn, done the inside so now onto the outside next... Link to comment Share on other sites More sharing options...
844john Posted January 14, 2020 Share Posted January 14, 2020 Very nice Ted, nice touch with the old number plates, we tend to keep our old ones as well! Link to comment Share on other sites More sharing options...
Dusty Dan Posted January 14, 2020 Share Posted January 14, 2020 Very interesting, nice work, as usual. Link to comment Share on other sites More sharing options...
Tractorman810 Posted January 14, 2020 Share Posted January 14, 2020 very nice, are you leaving it open? or will it get a set of doors fitted Link to comment Share on other sites More sharing options...
Ferret90 Posted January 14, 2020 Author Share Posted January 14, 2020 12 hours ago, 844john said: Very nice Ted, nice touch with the old number plates, we tend to keep our old ones as well! Cheers John 4 hours ago, Dusty Dan said: Very interesting, nice work, as usual. Thanks Corky Link to comment Share on other sites More sharing options...
Ferret90 Posted January 14, 2020 Author Share Posted January 14, 2020 26 minutes ago, Tractorman810 said: very nice, are you leaving it open? or will it get a set of doors fitted Not sure ,I’ve made some but it depends on where I put the barn Link to comment Share on other sites More sharing options...
Ferret90 Posted January 17, 2020 Author Share Posted January 17, 2020 Having a go at clay tiles... Link to comment Share on other sites More sharing options...
Ferret90 Posted January 29, 2020 Author Share Posted January 29, 2020 Making a cart shed with a granary above...I weatherboarded the side using balsa wood cut into strips. I were going to use wooden stirrers but they looked more like they should be on a barn conversion and not like the older ones... Link to comment Share on other sites More sharing options...
Stabliofarmer Posted January 30, 2020 Share Posted January 30, 2020 The wavy boarding looks spot on Ted, great work Link to comment Share on other sites More sharing options...
Ferret90 Posted January 30, 2020 Author Share Posted January 30, 2020 10 hours ago, Stabliofarmer said: The wavy boarding looks spot on Ted, great work Cheers James Link to comment Share on other sites More sharing options...
F8N Posted January 30, 2020 Share Posted January 30, 2020 Simply amazing Link to comment Share on other sites More sharing options...
Ferret90 Posted January 31, 2020 Author Share Posted January 31, 2020 17 hours ago, F8N said: Simply amazing Thank you Gary Link to comment Share on other sites More sharing options...
Ferret90 Posted February 5, 2020 Author Share Posted February 5, 2020 Got some of the timbers done inside...looking through the window into the inner barn... Link to comment Share on other sites More sharing options...
mb86 Posted February 5, 2020 Share Posted February 5, 2020 That's very realistic Ted. Link to comment Share on other sites More sharing options...
Ferret90 Posted February 5, 2020 Author Share Posted February 5, 2020 3 hours ago, mb86 said: That's very realistic Ted. Thanks Martin quite pleased with how the wood turned out Link to comment Share on other sites More sharing options...
