Tractorman810 Posted April 19, 2018 Share Posted April 19, 2018 being made out of plasti card the front end was hollow,so it was the easiest option, i guess your moulds are full as such so you don't have the route open to you ,i swapped ploughs not long after so it was pointless,but even a bomfords harrow would tip it Link to comment Share on other sites More sharing options...
tabmodels Posted April 19, 2018 Author Share Posted April 19, 2018 4 minutes ago, Tractorman810 said: being made out of plasti card the front end was hollow,so it was the easiest option, i guess your moulds are full as such so you don't have the route open to you ,i swapped ploughs not long after so it was pointless,but even a bomfords harrow would tip it Yes it's much easier to cast parts as blocks rather than hollow parts which require a two part mould, some weight could still be shaved off but it's not necessary thank goodness Link to comment Share on other sites More sharing options...
b_emmons Posted April 19, 2018 Share Posted April 19, 2018 looks amazing Ian waiting for the production line to start Link to comment Share on other sites More sharing options...
Valley Axe Man Posted April 20, 2018 Share Posted April 20, 2018 Very impressive build Ian. Well done for doing something different if a second one is in build with a tanker on it's back and sitting on wide boots that'll be a beast of a machine your building Link to comment Share on other sites More sharing options...
Hajo Posted April 20, 2018 Share Posted April 20, 2018 Marvelous Ian, very, very, very impressive endresult! Perhaps an idea to built something simulair to the dealership on page 4, and put all those amazing County's you have already built in front of that? Bet it would look totally amazing! Link to comment Share on other sites More sharing options...
JEP Posted April 20, 2018 Share Posted April 20, 2018 A masterpiece of 1:32 scale Agri-model building!! Link to comment Share on other sites More sharing options...
tabmodels Posted April 20, 2018 Author Share Posted April 20, 2018 4 hours ago, Hajo said: Marvelous Ian, very, very, very impressive endresult! Perhaps an idea to built something simulair to the dealership on page 4, and put all those amazing County's you have already built in front of that? Bet it would look totally amazing! Thank you very much Hajo! Funny you should mention the County stand, I had exactly the same idea after seeing that pic! Link to comment Share on other sites More sharing options...
Hajo Posted April 20, 2018 Share Posted April 20, 2018 We will just wait and see Ian ... keep up the good work! Link to comment Share on other sites More sharing options...
Stabliofarmer Posted April 24, 2018 Share Posted April 24, 2018 Just a ridiculous level of neatness and accuracy. Incredible! Link to comment Share on other sites More sharing options...
MDFord Posted April 24, 2018 Share Posted April 24, 2018 Love the detail and accuracy of this model Ian, it instantly looks "right" the cab alone is a masterpiece. Even the little chrome surround dual headlights are spot on, can I ask how you made them? Link to comment Share on other sites More sharing options...
Jd6320driver Posted April 26, 2018 Share Posted April 26, 2018 another fantastic build ian. Link to comment Share on other sites More sharing options...
tabmodels Posted April 26, 2018 Author Share Posted April 26, 2018 On 4/24/2018 at 5:47 PM, MDFord said: Love the detail and accuracy of this model Ian, it instantly looks "right" the cab alone is a masterpiece. Even the little chrome surround dual headlights are spot on, can I ask how you made them? Thanks Mark, it's basically the dual headlights drawn out on CAD in black line along with shadings and reflective shadows that makes chrome look like chrome. That is then printed on to the clear water slide decal sheet and then applied to chrome sign making vinyl, the chrome then comes through the clear decal and the black line drawing shows the detail. Link to comment Share on other sites More sharing options...
MDFord Posted April 26, 2018 Share Posted April 26, 2018 Thanks for the explanation Ian, a lot of work to go to for small details like this make for such a good replica. Link to comment Share on other sites More sharing options...
1/32 farmer Posted April 29, 2018 Share Posted April 29, 2018 wow that's absolutely fantastic tab Link to comment Share on other sites More sharing options...
tabmodels Posted May 6, 2018 Author Share Posted May 6, 2018 Here is the alternative version with County grill and floatation tyres... Link to comment Share on other sites More sharing options...
tabmodels Posted May 6, 2018 Author Share Posted May 6, 2018 And this is next on the cards... Link to comment Share on other sites More sharing options...
Cheshire Farm Models Posted May 6, 2018 Share Posted May 6, 2018 How you thinking of making the tank itself mate ? Something I’ve always wondered. Link to comment Share on other sites More sharing options...
tabmodels Posted May 6, 2018 Author Share Posted May 6, 2018 5 minutes ago, Cheshire Farm Models said: How you thinking of making the tank itself mate ? Something I’ve always wondered. Well after a bit of detective work with the customer it's going to be made using the Britains NC tanker. It's the correct diameter and will need shortened with plenty of added detail. Oh and it also needs to be detachable! Link to comment Share on other sites More sharing options...
mb86 Posted May 6, 2018 Share Posted May 6, 2018 20 minutes ago, tabmodels said: Well after a bit of detective work with the customer it's going to be made using the Britains NC tanker. It's the correct diameter and will need shortened with plenty of added detail. Oh and it also needs to be detachable! These customers of yours don't make your life easy do they. Link to comment Share on other sites More sharing options...
tabmodels Posted May 6, 2018 Author Share Posted May 6, 2018 1 minute ago, mb86 said: These customers of yours don't make your life easy do they. Very demanding bunch indeed haha! Link to comment Share on other sites More sharing options...
SPN Posted May 6, 2018 Share Posted May 6, 2018 1 minute ago, tabmodels said: Very demanding bunch indeed haha! There are only 15 very complex models on my list, not including the 5 new ones I'm going to add shortly. We still on for July 2021? Link to comment Share on other sites More sharing options...
tabmodels Posted May 6, 2018 Author Share Posted May 6, 2018 Just now, SPN said: There are only 15 very complex models on my list, not including the 5 new ones I'm going to add shortly. We still on for July 2021? It's not the models Stan, some people want them in fancy boxes too Make it August just to be safe Link to comment Share on other sites More sharing options...
tabmodels Posted May 6, 2018 Author Share Posted May 6, 2018 Just now, tabmodels said: It's not the models Stan, some people want them in fancy boxes too Make it August just to be safe That's August 2026. Link to comment Share on other sites More sharing options...
mb86 Posted May 6, 2018 Share Posted May 6, 2018 53 minutes ago, tabmodels said: It's not the models Stan, some people want them in fancy boxes too Make it August just to be safe Wait till they start asking for cretificates of authenticity too. Link to comment Share on other sites More sharing options...
b_emmons Posted May 6, 2018 Share Posted May 6, 2018 Amazing model and detail Ian When you work out a price to build them I really want one will it ready by August 2027 Link to comment Share on other sites More sharing options...
